ā2023-10-12 08:49 PM
I had this issue twice this week, the forum was all locked up for me so I could reply to posts. If I log out I cannot log back in, the login screen does not load.
I tried from a totally different computer, somewhere else in the city, so not the same network or IP, but I got the same thing. The issue did solve by itself the first time after a day or two. Happened again today, for most part of the day, until just now.
I'm in the Boston area of US, if that helps.
Any thoughts?
Solved! Go to Solution.
ā2023-10-12 09:08 PM
Thereās a post under Insights from Graphisoft explaining that they were disabling parts of the forum and making it read only on the 10th and 12th October. If affected everyone so donāt worry.
ā2023-10-12 10:58 PM
Thank you, Lee! I appreciate it. Clearly I missed the posts under Insights.
