4hotshoes
Updates to Forum Format are Good
I am just on this morning and noticed some nice features that were requested from users that are now on the forum. There is a better and more comprehensive list of topics. Also I can see that people have actually viewed my post even if they have not commented on it. These are good things. Thanks for the improvements. I hope other users will return to the AC Community.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
3 Replies 3
Erwin Edel
I've not been reading the forums for a while (too busy)  and just found out about the change. Does anyone know how to mark all forums as read without opening every single one of them?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Seems there is only a 'Mark as read' option for each forum.
however try this,
I am not sure if this will work though.
Use this link to find all unread posts.
https://community.graphisoft.com/t5/forums/unreadpostspage/tab/message/page/1
Now in the options do you see one to 'Mark as read'.
But I think you may have to select each post.
But I now see if you scroll to the bottom of the options you can mark all as read in the entire community.
Unless that is just a moderator option.
Erwin Edel
Thanks Barry, with the format more or less back to how things used to be, what I always did was read the sub-forums that hold my interest (and have some knowledge to help others out) and then after reading those, go to the top level and mark everything as read, but I'll try your solution.
www.leloup.nl
