Tactile warnings provide a distinctive surface pattern of truncated domes, cones or bars, detectable by a long cane or underfoot, which are used to alert the vision-impaired of approaching streets and hazardous surface or grade changes.
The Archicad GDL model includes all tactile patterns used as surface indicators to assist pedestrians who are vision impaired.
3 warning block tactiles and 3 directional block tactile patterns with brief description about where and in what traffic situation they need be used.
The studs and stripes are modeled at three levels of detail in both 2D and 3D views, so can be used in all kinds of plans.
Can be adjusted with editable hotspot to the desired application area with the option to set the distance and the stud sizes.
Both the application area and the number of studs can be listed and summarized.
Resin infill option to use custom colored insert material.
Hi i was wondering where we can download this object.
Hi, I am sorry, at this moment it is not shared, but soon I hope it will be, I will let you know!
Thank you!
Hi, you can download the object here:
https://bimcomponents.com/GSM/Details/25292
Let me know how do you like it, I am looking forward to hear your comment on it!
Thank you!
Orsolya
Hi
Is there any way you could create a download link . my Bimcomponents is not working, seeing similar issues on the forums
Cheers
"my Bimcomponents is not working"
Try with a different browser or clear the cache in you current browser for anything to do with Archicad.
I just tried and it downloaded fine.
Thanks, Barry tried everything, im still on archiad 25, but yeah tried a bunch of different browsers etc. and cleared cache
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
