One part - a free polygone with editable hotspots in 2D and 3D creates a street by using a Profile-manager-profile and curves all direction-changes with bezier-curves. It also creates in 2D a "sectionview" following the whole polygon with all Height-texts in a table - if you want that. In this section-view - its possible to adjust each Z-height also.
One other part is a ramp with the same features - and the possibility, to round the edges in Z
One other part is a T-crossing with profile-manager-edges (each diffrent) and adjustable in every way.
AC Edu-Aut: https://www.dropbox.com/s/vxqbm71ck5rur9w/Strassen.pln?dl=0
others: https://bimcomponents.com/Profile/b642d3f9-594b-42a5-ad35-8c86bce5f276
I have been waiting for this tool for a long time, I have the idea that Archicad is the only architectural design software that does not have the ramp tool, thank you very much for your effort in creating this object.
It's a great and complex artifact!
If there is a cross-shaped road intersection, it will greatly compensate for the function of ArchiCAD.
Thank you very much for your efforts in creating this object.
Can I adapt it into a Chinese version?
Yes - feel free.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
