"entire building" with slab-addon
Hmooslechner
Now You get an entire building on a slab with a view clicks at once. Its an Idea, which brings Archicad on its edges in preformance - (smile). Just an Idea for (fast??) surrundings around Your real design -(smile again)
in the meantime, i added profiles around it and made some bugfixes:
To try: AC26EduAut
https://www.dropbox.com/s/zpi4snwrk0ocsfh/Schnellfassaden.pln?dl=0
Comments
Hmooslechner
Some improvements to my new GDL for the Slab-Addon. Now it's a bit faster, on small edges, it won't put in Windows and I added some profilemanager-profiles on the perimeter, on the slabs and on the roof-edge. Later, it should be possible to change the geometry of the windows per story - but that's for later.
now on Bimcomponents: https://bimcomponents.com/GSM/Details/25227
latest: AC26EduAut
https://www.dropbox.com/s/wstv843f727vb3g/Schnellfassaden1.pln?dl=0
Jim Allen
Heimo - you are a GDL machine 😁
Hmooslechner
Little improvement - switch for windows per facade:
https://www.dropbox.com/s/ik08beaxejvoipv/Schnellfassaden5.pla?dl=0
yongler
Powerful GDL! Dear Hmooslechner
I would also like the following features:
1.  Add options for pitched roofs.
2. When dragging a hot spot, there can be three situations: window, windowless, and glass curtain wall.
Hmooslechner
Some improvements... auto-roof with adjustable slop-angles and hight-adjustments
german, but You'll get the points...
https://www.youtube.com/watch?v=x8TzlDSAA0Y
https://www.dropbox.com/s/ziz1z9p3ijpw8vy/Schnellfassaden7.pln?dl=0
Most liked authors
