Parametric design
About Rhino & Grasshopper and PARAM-O.
Archicad 26 (7004) crashes after connecting to Rhino 7
molumba
Hi,  I need to model some complex geometry in grasshopper to feed into our AC26 (7004 INT FULL) project.
When i connect the two softwares using grasshopper, Archicad crashes and  closes.  In grasshopper the sync is successful.
I have tried both the Live Connection installers from Graphisoft  that were supposed to work for Archicad 26 (win) and they both crash.
Grasshopper-Archicad_Connection-26-INT-4023-1.1
Rhino Version 7 SR30
(7.30.23163.13001, 2023-06-12)
What could be the solution?
Operating system used: Windows 7004 INT FULL
1 REPLY 1
Nurbs
Hi molumba,
It could be that the connection crashes due to the complexity of your Rhino geometry. Have you tried the connection with a simple geometry first?
A second test would be to import the Rhino file into Archicad without using Grasshopper and see what happens then.
AC16 - AC aktuelll , WIN 10
Setup info provided by author
