Gloria
Beginner problem with Rhino Grasshopper Archicad live connection add on
I am a beginner with connecting Rhino Grasshopper and Archicad... already running into teething problem.
I am using Rhino 7 and Archicad 25.
Got the add-on downloaded and installed in Archicad.  The Archicad tab is also showing when I start the Grasshopper.
In Archicad, The 'Grasshopper Connection' is not showing up in the 'File > Interoperability > Grasshopper Connection' as mentioned in the user guide.  But it is showing up in the 'Window > Palettes'.  Upon starting, the 'Start Connection' is functioning.
In Grasshopper, when I open the 'Connect Document to Archicad', the file is showing up in the selection menu and I can select it.  However, the 'Connect' button at is greyed out and doesn't let me press it.
Anyone knows why?  Hope it's a easy fix... looking forward to trying the feature out.
Thanks,
Gloria
0 Replies 0
