Column not rotating perpendicular to curve when base and end points aren't vertically aligned
Hey there,
I am having issues with rotating a column perpendicular to a curve when the base and end points aren't vertically aligned. The script I am using works perfectly if the base point and end point are vertically aligned. Any thoughts on what might be the issue?
See attached document for grasshopper definition.
Cheers in advanced!
3 Replies 3
Update: I have come to the conclusion that the definition is working, although, the columns can never be completely perpendicular to the top and bottom curves/points as this would mean that the column is twisting.
Image of resulting geometry for anyone that is interested.
Hi there Jarrod Phillips,
I am pretty new to Rhino and the Grasshopperlive connection and not yet very comfortable with the workflow. However, as i saw your 3d result I was wondering if you would/could share your Grasshopper script. I want to realize something very similar but i don't know where to start.
Kind regards,
Martin Pasman
https://rijnboutt.nl/projects/350
Amsterdam
the Netherlands
