2024-06-28 11:56 AM
Hello everyone!
i have a problem with param-o. i have made a very simple object, but in 2d i see only the outlines, i would like to add cover fills to this object.
i have searched online but i can't find any solution, i guess it is possible via 2d gdl script but i don't know gdl programming.
In the code I have PROJECT2 3, 270, 2"
is it possible to add something to make the object have a cover fill?
thank you infinitely for the help
2 weeks ago
I have same problem with parametrical objects made with PARAM-O (with different materials). Any recommendation?
2 weeks ago - last edited 2 weeks ago
Add a Fill command before the Project2
FILL name_string
or
FILL index
Swap your Project2 for a Project2{2}
PROJECT2{2} projection_code, angle, method [, backgroundColor,
fillOrigoX, fillOrigoY, filldirection]
You can set the Fill using a parameter so that the user can modify it.
Ling.
ps. It probably works with just Project2, just lacking control of the fill background pen. Cannot remember if there was a way to get the fill pen to use a different pen to your projection without resorting to Project2{4}...
