Jarrod Phillips
Extract Custom Parameters from Object Using Archicad Grasshopper Connection
Hi All,
I think I already know the answer, but wanted to confirm with others in the community if it's possible to extract custom parameters from an object using the Archicad Grasshopper Connection?
If it's not possible, do we know if this is something that's in the development pipeline? The extract object settings node seems kind of useless if you can't extract custom parameters?
Thanks in advance!
Regards,
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 27
You can use the tapir addon with its grasshopper plug-in
Archicad 27 - GDL - PYTHON
martyna_
Hii friends, I was wondering if you'd be able to help me. I am creating new archicad objects using geometry from grasshopper and I want to set surface atribute for all those objects. Do you think this plug in would make it possible? unless you know a way to do it without it?
