Fusion 360
Hudson
Hi I was wondering if there is any support for Fusion 360? I have been working with Rhino 3d and Archicad but have been finding Fusion 360 easier to make changes to custom objects since its Parametric. Is it possible to export objects from Fusion into Archicad?
Operating system used: Mac Apple Silicon Big Sur
Archicad 24, Rhino 3d 8, 3dsmax 2024 and Corona
Work: Gerard Smith Design
1 REPLY 1
I would check the list of file formats that can be saved from Fusion 360 and compare them to the file formats that can be opened by Archicad:
Archicads 28 Help - File Types Opened by Archicad
Hopefully, you will find a format that works between the two apps.
Setup info provided by author
