I have been trying different workflows on Grasshopper.
About to test a new idea but thought I would get some feedback first as I suspect part of the process may not be possible at the moment.
The idea is simple enough, create a mesh using XYZ data, get an aerial image (google earth), assign (assign might be the wrong word here) the image to a surface, map the surface to the top of the mesh.
I know the above can be done manually without too much hassle, but I have some other ideas that I'd like to tack on if I can achieve using GH.
Can anyone comment on whether this sounds possible?
I have a suspicion that surface creation is not a feature/function at the moment.
A previous test, which gets part way there:
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam Perth, Australia and Tauranga, New Zealand Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
