We value your input!
Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper Issues
Anyone help me with this error?
When I tried to create any wall/beam/column in grasshopper with ArchiCAD componet, I received error message as follow
1. Solution exception:Method not found: 'Void Grasshopper.Kernel.IGH_DataAccess.AbortComponentSolution()'.
1 REPLY 1
I suppose you have plugin wrong data type to the component.
It would be good to have some context to recreate the issue (pice of GH script with error).
