Parametric design
About Rhino & Grasshopper and PARAM-O.
Inconsistant Path when deconstructing objects
Adebar 799
Can anybody explain why the anchor points of deconstructed objects don't keep the path/Index of the original Objects?
There are multiple Objects in different paths. The path/tree structure seems to go through the deconstruct component but it won't keep the data.
Regards Ramon
1 REPLY 1
Nurbs
Hi Adebar 799. For me it looks like there is something wrong with your Data Tree structure. Unfortunately I can't see in the screenshot what is on the left side incoming to the "Explode Tree" node. Also the wires show that there is a wrong structure (there should be single wires). Try to sort them with flatten/graft etc. In general you should get what you want then...Data-Tree.png
AC16 - AC29, Rhino 5-8. Alienware WIN 11
