Parametric design
About Rhino & Grasshopper and PARAM-O.
Invalid Brep
Hi all,
I have a problem with the deconstruct window component. I'm getting some invalid BREP for the frame of the window. Attached there is a picture of that illustrate my problem. Let me know if you need the Grasshopper script.
Best,
Frank
I've used the null item component to get more information. Here is the error message I got for the invalid brep:
"Brep: ON_Brep has no faces, edges, or vertices"
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Is anything actually missing from the BREP, or do you just get the invalid item (but everything looks fine)?
It doesn't look like the window with the default settings. Could you send the GH and PLA to me (if there is only a single wall with a window in the PLA, that is the best), so that we can take a look?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
Hi Dkovacs,
mp sent
