sondermann
No reaction in Property Settings component
I connect a Wall Settings component to a Wall Design component. With connected number sliders I can change Height and Slant angle so everything works.
When I connect a Property Settings component and connect it to the related Settings input I cannot choose Properties or Classifications via right-click. The Property Settings input stays orange all the time.
The GH-AC connection works.
So what's the issue?
Best regards, Horst
ARCHICAD 26 3549 INT EDU APPLE SILICON
macOS Monterey 12.6
2 Replies 2
sondermann
I just installed AC 22 Build 4023, now it works. I am not quite sure if this was the solution though.
So still, any substantial info is very much appreciated.
Best regards, Horst
macOS Monterey 12.6
In my case it's working also on 4023
