yesterday
Where is the user manual for Param-o. The one that actually explains how to use this software. I am trying to create a window using this application which is adjustable in size where the frame sizes remain the same. It is really 3 sheets of glass with an extruded profile around the edge. Should be a simple task but seems to be impossible in Param-o.
Doest the customer support department for graphisoft actually exist in the United States. They never answer their phone
Operating system used: Mac Intel-based
yesterday
Hello, if I remember well with Param-O you can just build object no, windows, doors or skylights.....surely you can't manage 2D symbol differently from 3D projection, that is crucial for windows.......honestly I had great expectations when it was released, but with the passing of time it, sadly, became the typical born-death GS project, without any updates that fix the shortcomings of the initial release🤐
yesterday
Thank you for your reply but you did not answer any of the questions I posed here.
1. Where is the manual for Param-o
2. Does anyone have an example window made using Param-o
3. Does tech support existing for Graphisoft in North America or are we just wasting your $1000 a year.
yesterday
Here is more detail of the problem I am trying to solve.
Here is what I have so far. Note that the frame is on 2 sides not four. Note that if you change the dimensions the frames to not stay on the with the edge of the window
See here how the edges are out of alignment when you change the size of the window.
yesterday
I did end up getting Frank Hewitt to answer my request from Graphisoft here is what he sent.
3 hours ago
For parametric windows and doors, you will need to script them in GDL.
For non-parametric you could use the Library Part Maker add-on or just model them as slabs on the ground, select and 'Save Selection As' a door or window library object.
