Parametric facade
I am currently working on a project in which i have to cut holes in a wall using a parametric pattern created in grasshoopper.
I know how to create the pattern and establish the live connection, but i don't know how to actually cut the holes in my archicad element.
Could somebody pinpoint me to an instructional video or article on how to do that?
Thank you in advance
4 Replies 4
Eduardo Rolon
No idea but please do not double post your questions. If you want you can "bump" your previous post to "make it active" again.
If nobody has an answer to your question since then it means that nobody has any idea besides watching the existing videos for the Connection in youtube.
If you find one please post the link here so that others benefit from your search.
I already deleted your previous post
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Understood. Sorry for the inconvenience.
Have you tried cutting holes in the walls in rhino via baking the grasshopper facade and using a boolean operation and then transferring the resulting facade back via grasshopper archicad morph plugin?
Steve Jepson
Did you bring it in as a Hotlink module ?
