2023-09-19 07:43 AM
In paramo tool Grid Tool behaves strange way. If Count X or Count Y values are set to "1" nothing is shown in 3D. Only things started to be shown from value "2". In my opinion grid should not show anything if Count X or Count Y is set to "0".
Count X = 1, Count Y=2. Nothing in 3D. Count X = 2, Count Y=1. Nothing in 3D.
Count X = 2, Count Y=2. Finally 3D starts to be shown.
Please don't tell that Param-O is expermental tool and because of that it works not like it should be. This expermental tool is already implemented from version 24.
2023-09-19 09:08 AM
Have a look at the 'distribute existing object' example here ...
This lets you multiply in a circle or a grid.
Change the 'GDL object' node to an object you have in your library and attach it to the grid example.
2023-09-19 11:50 AM
Downloaded example, but that one also showing nothing when I change COUNT to "1" - in this value all elements disapears. Same issue in this one.
2023-09-19 02:15 PM
A value of 1,5 on count x & y will show only one object (not very logical...)
