Parametric design
About Rhino & Grasshopper and PARAM-O.
Place Hotlink with Grasshopper Live Connection
Ludovic
Hi, is there a way to place hotlinks from Grasshopper on target locations?
1 REPLY 1
Nurbs
Hi Ludovic,
Not in a direct way. But you can use a second AC file (be aware that it has the same attributes than the hostfile ! ) to create AC elements manipulated by Grasshopper and hotlink this file to the host. With AC 27 you can also bring the "Design Options" into play.
AC16 - AC aktuelll , WIN 10
