Parametric design
About Rhino & Grasshopper and PARAM-O.
Properties/Classification Component Bug?
JSN
I have an old definition created with the AC22 Grasshopper Components => it used to work alright.
Now after the update to AC23 I am not able to use the function of selecting classifications anymore …
Whatever I do, if I create the Components new they will not be accepted anymore by the Wall Setting Component – EXCEPT when I open my legacy file saved in the previous version AND DO NOT CHANGE IT because as soon as I want to modify classification or Properties it fails again
(Moreover it seems that in the last version it seems that classification from favorite components have been inherited => e.g. Walls has been a Wall - now in the new Version elements are just being created as ā€œGrasshopper Objectsā€ if you do not give them a Classification ... which is however not working as described above)
Is anybody encountering similiar issues?
(EDIT: Can a mod please move this topic to the correct AC-GH category?)
JSN
GS just confirmed this to me as a known bug.
JSN
Is there any update for the Livebridge in AC23 in sight as it still seems to be very unstable and those issueas are not resolved yet ....
