leceta
Text Parameter receives only 8 characters
I´am trying to pass string data from GH to my GDL object using Text Parameter, but I´am receiving only 8 character string on Archicad side.
Am I missing something? is this a known bug? Anyone experimenting the same issue?
thanks
aitor
2 Replies 2
Katalin Borszeki
Hi, we tested this and you are right, unfortunately it doesn't work well on Windows. We entered it as an error into our developer's database. Thanks for the note!! Until we can release a fix please try to use this function on a Mac, if that is an option.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
leceta
thank you katalin
