Parametric design
About Rhino & Grasshopper and PARAM-O.
Variable cross-section beam/column?
Is there any way to create a variable cross-section beam/column with the Grasshopper connection?
If I define it as a favorite it will still only create a constant cross section.
4.1 - - -
0 REPLIES 0
