ā2020-01-07
07:59 PM
ā2023-05-11
11:05 AM
Noemi Balogh
ā2020-04-06 09:17 PM
ā2020-04-09 12:40 AM
ā2020-04-09 10:13 AM
Bo_ wrote:Hi,
Same issue here. I run a MacBook Pro Late 2013 with Catalina 10.15.4 and a AC 23.4006 GER EDU and Rhino 6 and the connection seems to establish but nothing is shown in AC when I run GH. I have zero experience with Live Connection, could be I did something wrong, doubt it though. The wall got built after I ran the Python script by the way.
Same situation on my Windows 10 Pro 1909 running in Boot Camp, also AC 23.4006 GER EDU and Rhino 6. Wall gets built via Python, but the Live Connection doesn't work. I don't see anything at least.![]()
I would've tried AC 22 but couldn't find it on the website. Weren't older versions online in the past? Also haven't tried Rhino 5. But it would be great if there's a solution to the current issue.
Cheers.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
ā2020-04-09 11:37 PM
mnguyen wrote:
https://dl.graphisoft.com/AC/22/GER/AC/ARCHICAD-22-GER-3009-1.6.exe
https://dl.graphisoft.com/AC/22/GER/AC/ARCHICAD-22-GER-3009-1.6.dmg
mnguyen wrote:
I'm not sure if Boot Camp plays any part here...
ā2020-04-14 12:38 PM
ā2020-04-14 10:40 PM
Minh Nguyen
GRAPHISOFT
ā2020-04-16 04:38 PM
Minh Nguyen
GRAPHISOFT
ā2020-04-17 08:32 AM
ā2020-04-17 03:56 PM
justdhruv wrote:Hi,
I acknowledge you, for your efforts.
What kind of hardware is the issue With?
Regards, and thank you for all your help
Minh Nguyen
GRAPHISOFT
ā2020-05-19 09:03 PM
mnguyen wrote:Hi! I tried your test and it worked (the wall was built).
First of all, thank you for reporting the issue here and I am sorry about the experience!
We have a couple of reports recently about the connection issue with Rhino via Grasshopper add-on. To pinpoint the problem exactly, I kindly ask you to carry out the test below:
We will use a Python script to attempt to build a wall in ARCHICAD using the same port that the Grasshopper-ARCHICAD Live Connection add-on uses. This will help us to see if the problem is on ARCHICAD's or with Rhino's side.
1. Please download the latest Python version (3.8.1) from this website: https://www.python.org/downloads/
2. Run and install Python fully (with admin rights, it is very important)
3. Open ARCHICAD and start/activate the Grasshopper-ARCHICAD Live Connection add-on. (Rhino does not need to be running, as we are only testing things from ARCHICADās side now).
4. Download the attached file "Teszt.py" (Please make sure to have it located in the Downloads folder. This is very important)
5. Open the Terminal App and type the following:
sudo python3 /Users/<username folder>/Downloads/Teszt.py
(<username folder> would be the userās own username account. For example, my username folder is MNguyen so I would have it like this:
Sudo python3 /Users/Mnguyen/Downloads/Teszt.py)
6. Once you typed this line correctly, hit enter, and if you set a password for your account, Terminal will ask you to enter the password, after that hit enter again. Please take a screenshot of the Terminal App at this stage.
By now, please check if a wall was built in ARCHICAD, and let me know of the results.
Thank you for your help! I look forward to hearing from you!
Best regards,
Minh
P/s: Here is the link to the script:
https://graphisoft.sharefile.com/d-sb5de28c4d874b14a
