‎2019-08-01
09:53 AM
‎2023-05-11
11:06 AM
Noemi Balogh
Solved! Go to Solution.
‎2019-08-07 01:44 PM
‎2019-08-15 08:35 AM
‎2020-04-12 04:18 PM
‎2020-04-19 06:36 PM
Edoardo wrote:Hi,
Hi! I am having the same problem here! I fresh installed the latest version of ArchiCAD for Mac (I have an educational license, I don't know if that's an issue) and the latest version of Rhino 6 for Mac which runs the latest version of Grasshopper (1.0.0007) with no other plug-ins installed. I installed the latest version of the Grasshopper connection plug-in and reinstalled ArchiCAD latest version upon the already installed one. No cigar. I keep getting the message <grasshopper not running>. I need some help here! Thank you
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-05-19 08:37 PM
‎2020-05-20 09:08 AM
Edoardo wrote:Hi,
Hi! Thank you for answering.
No, I'm not using Catalina. I still have Mojave v. 10.14.6.
I'm using the plug-in with Rhino 5, but it crashes all the times making it basically useless.
I've also installed the newest version of Grasshopper-ARCHICAD-Connection 23-INT-4006-1.0 hoping it would fix the issue, but it doesn't.
Please help! Thank you!
Minh Nguyen
GRAPHISOFT
