Project data & BIM
AC BUG Discovered Line type
VladGoo
I just fiend a horible bug in all Archicad. Type line can't be changed eaven from specific window of the line setings without the cursor being diverted...
I use Macbook pro 16 OS13 Ventura, intel base.
.... I don't know what can we do to solve this problem as fast as possyble.
4 REPLIES 4
Miha_M
I can't fully understand what the problem might be, but it sounds like you might have some wrong renovation status or graphical override settings set. Screenshot?
| Archicad 4.55 - 27
I can't explain with screenshot because it can't capture the cursor (the arrow)
Can you take a photo with your phone and share that?
Ole
There was a bug report in the german forum which may be the same issue. Try changing the line type with the keyboard (up and down arrow, then Enter) as a workaround. Support has been notified.
for reference: https://forum.Graphisoft.de/viewtopic.php?p=168000#p168000
ARCHICAD since 4.55 | macOS current | AC 26 current
