‎2020-05-02 07:49 PM
‎2020-07-13 03:28 AM
‎2020-08-16 09:02 PM
‎2020-08-17 03:50 AM
‎2020-08-17 06:25 PM
‎2020-08-17 06:28 PM
daly2 wrote:YES I HEARD OF THESE - ARE THEY IN METRIC ALSO ? MM/ M ?
The Power Template developed by BIM6x comes with a metric Migration Library :
Take a look herehttps://bim6x.com/compare-bim6x-kits#field-products-tab-2
‎2020-08-18 10:20 AM
atfonit wrote:
schagemann - is this ONLY for MAC ?
‎2020-08-18 10:25 AM
atfonit wrote:As a long time Template developer / provider I am clearly biased - but do you have any idea how much effort goes into creating a proper ARCHICAD template?
Anyone can send me some screen shots if they use this ? at 399 US - Lot to pay if i dont like it or worse- i cant use it.
‎2023-01-02 08:03 PM
I have been working on building a Archicad 26 Metric Template for the office. Despite working in the US where they mostly use Imperial measurements, we do have projects that are mostly in metric measurements.
Thanks in Advance.
SOLEK
‎2023-01-03 07:36 AM
There really is no difference between an imperial and metric template.
It is exactly the same file, you just change the working units, calculation units and dimension styles to be the type of unit and precision that you want.
These are all found in the project preferences and you can change them at any time you want, even half way through a job.
