AC10-1176 Silent Install Problem
i tried to install the AC10-1176 Patch Silent over an Archicad Version 1010 as decribed in
http://www.archicadwiki.com/TechNotes/ArchiCAD_Hotfix_in_Silent_Mode
I tried this in an Dos box:
"AC10-1176.exe -W play.auto=yes -silent"
No Error occured and no Logfile is written ???
Also i couldn´t found an Autoupdate.log or similar on the system.
I seems to me that an error permits the Installation. But if i install the Patch manually everything works fine..
I need the Silent Installation because we use Archicad in an large enviroment where it is impossible to install the patch manually..
Please Help!
2 Replies 2
Does nobody has an idea ???
Greg Kmethy
You have to have the full path of the installer in the Run: command line, with the -W play.auto=YES extension. You will have sg. like this (in my example, the 1183 Hotfix installer is on the desktop):
"C:\Documents and Settings\gkmethy\Desktop\AC10-1183.exe" -W play.auto=YES
Note that the path is between double quotes, there is a space after it, and there is a second space after the -W parameter. You don't need anything like the -silent parameter
Gergely Kmethy
VP, Customer Success, Graphisoft
