Eduardo Rolon
AC26 Stair Bug: Editing Settings from copied stair resets parameters
After copying a stair from one 26 file to another if you edit its settings it resets all other display options.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
2 Replies 2
Eduardo Rolon
Looks like when the stair is pasted in the file it does not read the MVOs from the current file.
The File from which the stair was copied that different MVO settings.
AC29 US/INT -> AC08
Lee Hankins
MVO’s are a nightmare. I often update them in the template file then export them out to import in to active projects. They won’t overwrite and all end up named with a ‘(1)’ after the name. Even if you delete the original versions and rename the new ones exactly the same all the views then as the MVO is ‘missing’
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
