Project data & BIM
Any way to Copy+Paste a module but retain the hotlink...?
That is, Copy+Paste a module into a different PLN file.
Whenever I do it, it breaks the hotlink, copying "copies" of the elements that make up the module, into the target PLN. It keeps them as a "group", but that group is no longer a hotlinked module, disconnected from its original source.
Any way of making it keep the hotlink?
4 REPLIES 4
Erika Epstein
Place the module in the file, as you should have done for the first file.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yeah, I was trying to avoid that. It's not so simple when you have multiple modules all with differing elevations needing to be set (as in the case of a neighbouring building with multiple stories, with differing storey heights). In addition to the xy origin of each module too.
And when re-Placing the module(s) , there's also the extra step of deselecting the modules in the source PLN when you COPY.
I know it's not a showstopper, but it's a pain compared to a simple "Paste Special > Retain Hotlinks" option.
Erika Epstein
Instead of replacing, break the link and link to a new module.
Have you tried just copying the file?
Hard to really help when you don't tell us what you are trying to achieve.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Is 'Suspend Groups' unchecked in both files when copying and pasting?
