2021-05-19
11:43 AM
2022-09-22
06:07 PM
Oleksandra Vakariuk
Solved! Go to Solution.
2021-07-21 04:08 PM
2021-07-21 04:32 PM
A. wrote:All MEP objects must work, as I designed and used them on my projects. There are two reasons why objects can give error - when data files in embedded library are missing (they embedded by default into template file) and when ArchiCAD MEP library is not connected, because my objects - it's a modification of standard objects and part of object functionality is requested from MEP macro.
May I ask - only I have troubles with placing pipes objects ? In my case even 3D preview page of object shows error. I see only their image. Same for tees, elbows etc.
I didn't look through everything, but others seems to work fine.
Thanks Podolsky, for sharing.
Looks like your skill level of ArchiCAD and GDL is almost unreachable.
2021-07-21 06:30 PM
Podolsky wrote:You're right - MEP default library wasn't embedded ... (facepalm)
2021-07-31 09:24 PM
Podolsky wrote:Thanks for the template! Get well. Greetings from Kyrgyzstan!
Hello all. Seems that I cannot continue this development because of health issues (serious spine problems). Anyone who is willing to pick up my libraries, modify or do anything about it - feel free.
The password to the scripts 'neilsmith'
Cheers
2021-09-07 05:09 AM
Thank you so much!! Your work is amazing
Greetings from Mexico
Hope you get better
2021-12-08 07:34 PM
the template is very complete for UK standars , congratulations, Greetings from Mexico
2022-03-07
11:40 PM
2022-03-08
02:35 AM
Good day may you kindly share the passwords required.
2022-03-08 02:29 AM
It was written in a previous post - yes there is a lot to read.
2022-03-30 11:45 AM
Thank you Sir. Can you help me able to change tittle block??
2022-06-28 09:51 PM
Wow. Thank u so much. This is awesome!
