Archicad 18 - Hotlink with Multistory Active
Archicad 18 - Build 4020
Windows 7 - x64 (all up to date)
Nvidia Graphics - GTX570 (latest drivers)
Am I the only one with this annoying delay, when I use a Multistory hotlink to my model?! It takes ages when you select the model on plan to activate, then there is huge delays when I try and move it.
With single story hot-linking there is no problem, but I have so many floors I need to use Multistory!
Any suggestions, help!?
4 Replies 4
Erika Epstein
Put the above info in the signature of your profile
Just how many floors are there?
Do you need all your layers showing?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I don't know why the amount of floor is relevant because I tried even with just 2 floor, and brings everything to a standstill when I use the Multistory function.
Back in the day I placed 10 floor Multistory buildings on a Site layout with no hassle...
The multistory building has minimum info so layers are not relevant either...
I know that the use of Cadimage has caused serious delays in placing of hotlinks, maybe this is happening again I will have to do a clean install without any plugins or use there of.
I will report back. But has anyone else experienced this?
Erika Epstein
Zak,
Don't yell when people here are trying to be helpful.
I have no problem placing multi-story modules.
You mentioned many stories, so it's logical to ask how many and how large a file. While Archicad and other similar programs have improved quite a bit over the years, there is a point where large and/or complex projects can began to bog down a file.
Trying to get at your problem, you are now adding information such as your use of CADimage and known problems using it.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Matt Balaam
We use multi-story hotlinks all the time without any slow-down.
We don't use any third party tools, only in-house developed objects.
AC29 AUS | Windows 11 | Intel Core i7-12700 @ 2.1GHz | 32GB RAM | NVidia T1000
