Project data & BIM
Archicad 24 wall recesses are not added to zones
I have made my zones manually (the reason for this is that I need to add all door area to the room) in Archicad 23 and they automatically add windows to the area. However when I transferred my file to Archicad 24 and updated the zones, the window area was taken away, it only works if I change it to the automatic zone. Is there a way to fix this or I have to draw all the windows manually as well? Or maybe just go back to Archicad 23?
Thanks, Liene
7 REPLIES 7
I wouldn't have thought it would be any different.
Are your zone preferences set the same?
Yes, they are!
You can see here - two rooms which are the same size, but the measured area is different.....
I just tested in and indeed 24 is different to 23.
Why - I don't know.
I just skimmed through the new features of 24 and saw nothing mentioned.
I also checked the reference manual for Project Preferences and saw nothing mentioned.
Looks like this is one to contact your local Archicad support people about.
Of course with a manual zone you can stretch it into the window reveals - which is not ideal.
Okay, thanks for looking into it!
Minh Nguyen
Graphisoft Alumni
Dear All,
Thank you very much for sharing your findings and I am very sorry for the experience!
I was able to reproduce the issue in Archicad 24. I'm not sure whether this is intended or it is a bug, thus we have open a support case in our system for further investigation. As soon as we have an answer I will let you know.
Thank you once again, and have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Perhaps something related to the "Relation To Zones" wall settings.
Minh Nguyen
Graphisoft Alumni
With the help of our colleagues, we identified the issue and enter it as a bug (DEF-6042). I hope that the issue will be fixed soon!
Thank you all once more for sharing and reporting this issue!
I wish you a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
