Project data & BIM
Archicad 9 OSX Launch
Can someone please explain to a NEW Mac/Archicad User how to open Multiple Instances of archicad/Plotmaker V9
4 REPLIES 4
Link
Simply copy the application files (ie. ArchiCAD & PlotMaker) in your OS!
Link.
Dwight
and these new copies should be renamed like "ArchiCAD 2," say.
if you put the icons in the dock, it is easy to drag the second file onto the new icon to open it so the first application doesn't get confused and try to close the first file.
Dwight Atkinson
Eduardo Rolon
If you use Quicksilver ( check Versiontraker) you can launch as many sessions as you want without having to make a copy of AC.
check post
http://archicad-talk.graphisoft.com/viewtopic.php?p=29352&highlight=quicksilver#29352
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks So much i was trying to do it with an alias
Quicksilver is awsome love it thanks
