MPHz24
Arrow Keys in AC28
I can't seem to find the shortcut/command to use the arrow keys to pan in AC28.  In previous versions, I could just use the arrow keys to pan left/right/up/down slightly; can't seem to get that to work with 28. I've scoured the shortcut scheme to no avail; I must be missing something.  I've grown quite attached to this setup, any help would be greatly appreciated.
3 Replies 3
You need to look for "Scroll" which is a little different to the "Pan" command but does the same thing.
Mine is already assigned, but I am also using a Work Environment imported from an old version.
You can reassign these to the arrows.
CSvercl
Same problem.  Need to find a way to use the arrow keys to see a little to the right, left, up, or down on the screen.  Already have zoom on mouse.
When I go to Work Environment, Keyboard Shortcuts, and type "scroll" in Search Commands, it only brings up "Show/Hide Scroll Bar".  Not what I want.  Or search for "pan", it brings up Railing Panel and Panel - not what I want.
Make sure you are searching in "All commands in alphabetical order".
Otherwise you will only see the commands you have already used in you menus/toolbars/shortcuts.
See my image, it is there.
