Brian Gilliland
Pet Palette Short Cut
Is there a way to set-up a key command to enter the tool options pet palette, select the feature you want and then return to drafting. For instance, I select the line tool and draw a line. I then want to make it a curved line. I would hit the key command to open and enter the line tool pet palette and use the arrow keys to move within the palette until I get the curved line tool highlighted. They hit return to accept and return to drawing. I think this feature would expedite drawing because you do not have to stop drawing, find the palette, move the mouse to to the palette and select the feature you want, then return to drawing. Thanks -Brian
7 Replies 7
vlahtinen
You can move to the next editing option in the pet palette with F and to the previous one with Shift+F, if I’m remembering the shortcut correctly and you haven’t overridden the default keyboard shortcuts. But you have to first bring up the palette by clicking a line.
Grover
The F and Shift+F keyboard shortcuts, which are essential for efficient workflow, are currently non-functional in ArchiCAD 28 for Windows. This issue, which has been present since the beta preview, is significantly hindering my productivity and has not been addressed in the final release. The documentation incorrectly states that these shortcuts are enabled. Archicad 28 Help
runxel
Just set them up yourself then! 😄
Most if not all users are carrying their tailored keyboard shortcuts from version to version anyway.
It changed to P, SHIFT+P and ALT+P (I did see it documented somewhere once).
It seems the help documentation has not been updated.
As runxel said, you can change it back if you want.
I guess 'P' for Palette makes more sense than 'F'.
I would say the arrow keys would be more logical.
Found it ...
https://help.graphisoft.com/AC/28/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC28_Help%2F005_NewFeatures%2F...
Seems 'F' is now Flip which was 'P' before.
Makes sense, but why change now after all these years.
Lingwisyer
Guru
It was probably said the last time this topic came up, but whoever changed the shortcut to P has obviously never used the program, or any shortcut heavy program in general, since moving one of the most used shortcuts to opposite side of the keyboard, especially one with a modifier, is an IQ0 move. Or maybe they use a DVORAK keyboard and AC shortcuts are hard coded to the glyph, not the key...
changmarin
This is nonsense... come on! You grab the mouse with one hand  and strike the keyboard with the other, hands always on the wheel.  What is more important, that Flip or the short cut used thousands times a day?  Just to pair it whit the F??? CTRL+SHIFT+ALT+F but let the palette alone.  Many awful things in 28.
I founf this topic because I was tired of F and Shift F not working.
Thank you guys.
totally nonsense.
by the way Graphisoft, give us F13-F24 so that we can use more shortcuts and macros
Versions 12 to 29
AMD Ryzen 5700x, 32GB RAM, RX580 8GB
Windows 11 & OS X Monterey
Intel Core i7-13700KF, 64GB RAM, Nvidia RTX 4070 SUPER 12GB
Windows 11
