Any new revision control system needs to be forward thinking as well. So far the discussion has centered almost exclusively around changes to printed documents (or their PDF equivalents). But as we move toward more and more sharing of model data directly with other project team members an entirely new revisioning landscape opens up. This in turn needs to flow from the still nascent conversation the construction industry is having about how exactly to accommodate such sharing. I know this scares the bejeezes out of a lot of people, and rightly so, but this brave new world is now a fact of life for architects. Digital collaboration on high profile projects is earning a lot of headlines. Depending on how long you plan to continue practising this will trickle down to firms of all sizes, just as CAD and BIM have. Graphisoft can ill afford to ignore this as Microstation and Revit are garnering most of the attention. Check out these articles about this year's AIA BIM awards as an example,
part 1 and
part 2.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
