Nic Tulban
Building materials properties
Is there any posibility to use the Building Material Properties and Classifications in calculations of other properties and furthermore in scheduling?
For example, I want to calculate the weight of an component element and to list it in a materials schedule. The calculation should be as a property represented - the result of a product between density and component volume. I cannot find any acces to oBuilding Material Properties in the Property Manager panel...
0 Replies 0
