You mean that there are no bubbles in the cloud and it is only straight line segments? That usually happens when the cloud shape is set to Polygonal, but that is not the case on your screenshot.
Can you transfer the parameters of another Change Marker that works? Or delete it and recreate it?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
A colleague sussed it out. In the Issue Settings you can choose to only the current issue back to only a certain issue or only the current issue. The Change Markers that were "hiding" their polygon lines were from a previous issue and the Issue Settings were set to show only the current issue.
AC versions 3.41 to 25 (UKI Full 5005). Using AC25 5005 UKI FULL Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
