We value your input!
Project data & BIM
Cleaning property Manager
iggiv
Dear Madam/Sir
I am trying to clean out my property in the Property Manager where I have duplicate folders. I have deleted the folders after making sure there are duplicates in other folders, but they do not get deleted and instead become light gray. I notice that they also show up in other related areas, and they are also in gray
Does anyone know how I can delete them so I do not have duplicated properties?
figge
They could possibly be located as part of another linked file (xref, hotlink etc.) and therefore not being able to be deleted.
W10 Pro | ArchiCAD 27 6000 AUS FULL | Twinmotion 2024.1
figge
iggiv
Dear Figge,
You were right. That’s what the help window indicated. I cleaned up everything that wasn’t needed in one of the files and solved the issues, I think they might be related to hotlinks in the template. I’ll need to check the original to confirm if removing them will resolve the conflict.
I believe this is the root of the problem. It’s going to take some time to clean everything up, but hopefully, this will fix the issue.
Thank you for your comments, I thought I had updated the hotlinks.
