Project data & BIM
Column Main Construction Type
mukster
I want to add something new in COLUMN TYPE IN MAIN CONSTRUCTION but I can't. I only see some already option.
Operating system used: Mac Intel-based
CosminF
You need to edit the values available for that Property.
Go to Options > Property Manager.
Find the Column Type property (as in your image). There in the value definition, you will have an Option Set.
Go to Options Setup and add the options you want added.
Click OK and that should be it.
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
CosminF
Thank you
