mukster
Column Main Construction Type
I want to add something new in COLUMN TYPE IN MAIN CONSTRUCTION but I can't. I only see some already option.
Operating system used: Mac Intel-based
1 Solution
CosminF
You need to edit the values available for that Property.
Go to Options > Property Manager.
Find the Column Type property (as in your image). There in the value definition, you will have an Option Set.
Go to Options Setup and add the options you want added.
Click OK and that should be it.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
CosminF
mukster
Thank you
