Comand H (Hide) on a Mac is disabled
I loose my command H quick key for hiding the Archicad after exporting my work environment. Have other Mac users experienced this problem? Anyway to get it back? I use command H all the time, but would also like to be able to export my work environment. Thanks for any feedback.
11 Replies 11
Dwight
That's a system command, not an ArchiCAD command. Do you mean to say it stops working or disappears from your list?
Not for me.
Dwight Atkinson
Aussie John
command H is used to stretch so there is a conflict between ArchiCAD and the system
Cheers John
[/size]
Dwight
Aussieboy:
Say what?
As soon as I hit command-H ArchiCAD disappears.
Command-H no longer on USA version command list - always using the doggie pallet.
[Better than saying feline palette, but said instead with a word changed to improve alliteration - sort of like enjoying vegetarian dishes but preferring them with meat.]
Dwight Atkinson
Aussie John
For some reason I changed the shortcut for stretch. So maybe it does work now. I'll Have to check.
EDIT: sure enough command H hides Archicad. (probably why I had to assign a short cut for stretch)- thanks wonderboy:
Cheers John
[/size]
My command H is there if I do a new and reset and load the default work environment. I can update parts of my work environment (everything except "command layout schemes" and the command H (for Hide) is available to me. However if I export a new work environment, the shortcut is no longer available. The shortcut functions correctly in all other applications.
Aussie John
Mike you havent turned it off in the system keyboard shortcuts?
Cheers John
[/size]
No. And as you can see it is well and happy in other applications.
__archiben
not sure if i'm understanding you correctly, but will either of these posts help any?
http://archicad-talk.graphisoft.com/viewtopic.php?p=22328#22328
http://archicad-talk.graphisoft.com/viewtopic.php?p=26235#26235
~/archiben
b e n _ f r o s t
Stress Co_
Mike:
I too lost the ability to Hide using command H (It's my stretch shortcut).
You probably already know this (it doesn't exactly "hide" Archicad or mean to solve your issue), but .... do you use the Expose' system preference? I use it all the time to "hide" Archicad (and everything else). F9-F10-F11 or set it for use with Active screen corners.
A bit off topic, but I just learned this tip for OS X: To zip/compress files and folders I always opened "Stuffit" and dragged file/folders to it.
Instead, you can compress from the finder window with: Create Archive of "file/folder".
Marc Corney, Architect
Red Canoe Architecture, P. A.
