Complex Profiles Problem
Hi guys.
I have a problem with complex profiles in Archicad 10. In that when I Purge Unused profiles in the Attribute Manager, they come back after I have resaved the file after working on it again.
an example.
I'm working on a large building which I have created a number of profiles for the curtain wall system.
The building is split into 3 modules, which are then linked into a master file.
If i'm working on the tower module and make or amend a profile that I have created, it seems to bring in all of these unwanted "default" profiles back in. Which then show up in the master file after I have updated the modules. Is there a way to stop these profiles from coming back into each file?
I've even gone to the extent of creating a blank master file with no profiles, and remaking the ones I want, and then importing everything into the new blank file, which seemed okay, until i checked in the attribute manager, and the default profiles came back in!
Any help would be really great.
Thanks, Rob.
2 Replies 2
David Larrew
Are you working in .MOD or .PLN files?
.MOD file attributes are "transparent" - they take-on file attributes of the previously accessed .PLN file. If you are working in .MOD files you are wasting your time trying to purge attributes.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Laura Yanoviak
Unfortunately, it's an apparent bug.
