Revision Cloud shows fill pattern
I can't get rid of a fill ('Ceramic Tile 150') on a Revision 'Cloud'.
Have tried turning off various attributes, and stopped production in the office for 5 minutes while everyone had a go, to no avail.
Anyone got any ideas?
- Keith
(Release 10 on Mac Platform)
3 Replies 3
I had no problem just changing the fill in the Parameters / 2D representation tab. I don't usually use this object tho', just a spline with the revision linetype. Much more flexible.
- Keith
If you try all kinds of parameters of the object, and the Fill types still doesn't change, you might want to try to open the object for editing, open its 2D Symbol window because the symbols might be pre-drawn there.
Make sure to make all fragments 1 to 16 (the equivalent of Layers in objects) visible.
In this case you need to manually modify the Fill type of those Fills drawn in the 2D Symbol Window.
That worked, thanks, Laszio. However the next problem was that the cloud refused to be stretched using the pet palette.
So we'll take your advice, Stuart, and use splines.
Thanks, guys.
