Convert zones to dwg
Hi!
When I convert AC files to DWG i want every symbol and text and everything to be "by layer" so that when I open the dwg I can change the color of everything by changing the color of the layer. This works fine except for room name and room number in zones wich becomes a block and is in need of manually changing of colors. Any tip on how to solve this?
//Maria
You may try to create Custom Layers for Zone Stamps and Zone Texts in the Attributes\Layers\Methods page of the Settings in Selected Translator panel of the DXF-DWG Translation Setup Dialog.
That will place those on separate layers (and I suppose this way they will not be part of the block generated from Zones - I have not tried it)
The Zone stamp becomes a block with the color by layer but the text becomes block attributes and is given a color within the block that is not by layer.
