Copy Layer Sets
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-07-17
10:42 PM
‎2023-05-30
12:52 PM
Rubia Torres
- Labels:
Project Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-17 11:20 PM
Any better ideas out there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-17 11:41 PM
I told a reluctant new ArchiCAD user that the board would help. They are "one of those" that fights it every step of the way kind of people. Lots of moans and groans, lol
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-17 11:48 PM
- a) If the document set is not so far along (limited section/elevation annotation, and few layouts) it may be easier to just duplicate the PLN file with the correct layers, then wipe out the old model data and copy/paste it in the model data from the PLN with the deficient layer combo's. But Gawd, is this what we've been reduced to?
b) If you have elements in plan on all the new layers you need, you could just turn everything on (visible and unlocked) and copy paste all elements into the file where you need the layers. Once done, delete it all. That will at least create the new layers and save you the chore of typing in all their names. The layer set assignments must still be done manually.
Another related annoying thing is that if you change the name of the layer set, the view map can't find it anymore. That is truly lame.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-17 11:52 PM
anyone else have any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-18 12:16 AM
Chazz wrote:Attribute Manager DOES do that, actually.
I don't think it's possible. Attribute Manager won't do it, anyway, and I lament that every time I use it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-18 12:21 AM
Chazz wrote:Well, I just tried it in AC12, and it seems to work fine. If you start with a bunch of layer names that are not in the source file, it does become quite a mess to clean up.
I don't think it's possible. Attribute Manager won't do it, anyway, and I lament that every time I use it. <snip>
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-18 01:02 AM
TomWaltz wrote:Well...Chazz wrote:Attribute Manager DOES do that, actually.
It does work to the extent that the layer names
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-18 02:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-07-18 03:32 PM
TomWaltz wrote:A.M. brings in the names of the layers and the names of the layer sets but does not bring in the crucial relationships betwixt the two. To my mind a stunning shortcoming. If attributes like this could be moved easily from project to project it would make template maintenance much easier.
