Copy multi story buildings
I have a 2 story building and will repeat a few times through the project. Unless I use hotlink , is it possible to grab 1st and 2nd floor at the same time and copy to a new position or I need to do it floor by floor. I guess marquee would be able to help me , but don't know how.
Any masters out there?:)
2 Replies 2
Laura Yanoviak
Turn on and unlock all desired layers -- use the thick Marquee to select the building, and Drag a Copy. Although I would recommend using Hotlinked Modules instead.
Great cheers Laura
