Project data & BIM
Disable BIM Components downloads
Hello all,
I wonder if there is a way to permanently block the downloading of objects from BIM Components within Archicad. I would like to personally manage the objects that the architects will use in the projects instead of giving them the power to download (often unintentionally) library objects not approved by by me.
Any suggestion is welcome.
Thanks
3 REPLIES 3
Miha_M
Add BIMcomponents.com to your Firewall blacklist?
Don't register Archicad with the BIMcomponents website?
| Archicad 4.55 - 27
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Have you tried editing the Permissions in their Roles in the BIM Cloud Manager?
Disabling "Libraries add/remove", Library part - Create", "Library part - Delete/modify".
Haven't tried myself, but sounds like to me that it might do what you need.
Ghaleb Khadra
Graphisoft Alumni
Graphisoft Alumni
What @mbl said it true.
"Disabling "Libraries add/remove", Library part - Create", "Library part - Delete/modify"."
That works in Teamwork environment.
Thank you @mbl for posting your answer here.
Kind regards,
Ghaleb
Ghaleb Khadra
BIM Expert
GRAPHISOFT
https://helpcenter.graphisoft.com
