Sort of, I ended up making an excel spreadsheet based on the document transmittal system I found in the Skewed S21 template
http://www.skewed.com.au/blog/skewed-s21-bim-template-archicad-21. It uses ArchiCAD to generate some Issue and revision text documents, these can then be imported into excel and will automate the filling in of the issue sheet as long as the correct date and issue are input into the box at the top.
It took a bit of fiddling around with the project indexes to get the right stuff exporting but if you follow the guide in the Skewed template it's fairly simple.
I can't seem to attach the excel spreadsheet but may be able to email you if it would help. Setting up the formulas so that it would auto fill from the info provided through archiCAD took a bit of time and may have some issues but it seems to work most of the time for us.
ArchiCAD 24 NZE FULL
Windows 10 Pro 1909
Intel Core i7-6700; 32GB RAM; AMD RX480
